be cheaper to tuck it between your legs, but hey whatever really
it would be, or for mroe of a permanent fix, stitch it to ur leg
i wonder when they go for the snip, if they replace the 'internal's too :wub:
hey guys, on the way home from worktoday my window motor decided to die in drivers side door. (im sure this is the problem) it made some verwierd crunching sound beforehand when the window was fully wound up. anyway, does any1 know any1 with a window motor and regulator system for R33?? or where to get one for a decent price??
hahaha this page is f**king funny
yes, we were bored, and when we're bored i think a bit of shit comes out :wub:
how u goin mate?
no idea big fella, maybe get onto the wreckers, and even give dan (3lit3 32) a pm/ring to see what he can get
yes, we were bored, and when we're bored i think a bit of shit comes out :)
how u goin mate?
yeah i gotta get it looked at first, my window was up when its broke so that is the good thing. but im just gonna try and find the parts then i will buy what i need. i mite only need a motor i dont know yet.
There were three or four guys wrecking 33's in the classifieds over the last week or so, Might be worth a search.
yeah i was looking but could find any that were wrecking there's. but i guess i should have looked in the qld section instead of the national one DOH!!!
thanx :)
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
