Come work with me for one day and see if you can hang with the old coot you soft young pup. :)
i'm fat, lazy and get good money for sitting on my ass all day in air con mostly surfing the net, yes i'll be out there next wekeend! :)
Yay, noel and shane always liven up whoretown.
what can i say, i aim to please? :)
Fark i am a good cook. I just opened a whole can of Campells soup on my own.
shit aye, no bones crumbled under the severe stresses they would have been under acting upon such a large mass of a campells soup tin?
shit aye, no bones crumbled under the severe stresses they would have been under acting upon such a large weight of a campells soup tin?
We'll see what it does to bones when I throw the farkin thing at your head. :)
And wood is very tuff.
i hear it's quite soft and porous...
BTW, Did i tell you how tuff my new Wheelz look?
not sure, but i had some old codger ring me before blabbing on about some shit, wasnt paying any real attention...u were saying?
I was saying...Pulling yourself makes you deaf, Didnt you hear me?
hey guys,
the other day i was looking at some skylines and i came across one with sissor doors and thought it looked really tuff..!!, im not planning on getting them but i was wondering how much it would actually cost to get them, if anyone knows or is interested wanna help me out. thanks guy!
Scissor doors hmm defect problem there
Plus they arent that great for our heavy skyline doors the mounts will eventually break or well push into the door itself or guard goodluck on that one :D
Oh hey andy
Lots of money and, from what I hear, a nightmare to get engineered (for both legality AND longevity). They'd also add a fair bit of weight, which means a slower and more thirsty car.
If you're dead keen, ask around at places that do autosalon-type cars, there have been a few scissor'ed cars over the years.
hey guys,
Been gay long??? :P ha ha
Serioulsy but it is gonna cost you so much money to get then on, looking good and legal! Spend it on suspension and Tyres instead :O
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
