but it still doesn't have any corners :P
Just between you and I at the end of the straight is the sweetest corner in the bus Andy. Damn i get a good drift going when i turn off the track :laughing-smiley-014:
The officials must love that!
lets make it a date. Get a few lines together and go play.
My May is a very big MAY, but you are welcome to post it up
The upside is by then I should have a TV operational in my car, so if I can watch the game I am more likely to come..the biggest obstacle is getting all my boring tasks finished on the car in time
hmmm looks like my cams arriving in may big time in may for me, :P bah if you want corners theres many bypasses on the way back from willowbank that has twisties in them if you need that lease on life andy, heh see that mountain "Run" advert in events someone is organising i thought you couldnt?
What cams??? My cams are yet to do jack...I think I need some cam wheels to set them up properly
Legal corners are more fun
I did notice that post...but really I couldn't be bothered anymore, all hail the mountain kings
Meh! Just record the game like me and go play. :(
You recon worth while dialing them in do ya andy? gone the poncams at least there well enough for me atm :) Lol at the mountain kings comment
Yeah I went poncams too...yet too see any great results from them, So I think I need to dial them in
Noel your fondness for driving in straight lines in a car that was designed for a higher purpose concerns me :(
And its more than the game I have work to do :S
Noel your fondness for driving in straight lines in a car that was designed for a higher purpose concerns me :)
Dont be too hard andy. It's my bogan roots. :(
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
