I so totally like not having water restrictions.
You water that sleeper joshy!! I loved the lack of water restrictions up there too not that I have any here, but i had a spa in my hotel room and it got used...every night....ahh the waste!!
God damnit...
Still no oil preassure...
Does anyone know how long ud have to crank an engine with a oil cooler just added before itll show preassure on the engine?
Did you top up the oil level?
With the addition of an oil your oil capacity can be up to 2L more. Where's abouts is your oil pressure sensor located?
Well im not only sun burnt...
I have a cold, I stood out in the sun all day feeding a concrete mixer with sand, cement and water.
I got burnt and covered in crap, im dirty and tired and dehydrated and sore...
I had to do a real days work, and I feel like a chump!!!
Maby I should get a real job............................................... Nah :P
Yeah I gave up this shit for a desk job with travel...
My fingers are soft now and all i have to worry about is paper cuts...
But to be honest I had fun, and it was great to get out doors and do something for the day...
Makes me feel less guilty when I eat a huge steak for dinner... :P
    • Still fast enough to have fun (kinda). Time for a modern turbo with a divided turbine housing and a proper twin scroll manifold. I think 400-450kW is a great place to be, provided it's all in before 4500 rpm.
    • i'm not at 600 though 😢 its 484hp (356kw) at the wheels..
    • Nice. 600ish HP is probably a nice place to be.
    • In the US the EPA has been going after shops that sold aftermarket ECU tuning software that allowed you to disable CELs for things like EGR, DPF, SCR, or TWC failure. They also went after shops for selling emissions delete equipment. Their logic is that all cars built for street use have this emissions equipment and you cannot do an after the fact conversion to an off-road vehicle not intended for street use. Cobb, Hondata, and similar companies have basically all revised their tuning software such that going forward you cannot suppress DTCs for emissions-critical systems, nor can you toggle systems on and off in the tune like EGR. You also cannot adjust OBD emissions monitoring logic. You can still tune these cars. But you have to do things the hard way, basically. For example Subaru FA20DITs used to delete the TGV system to get spare analog IO for a flex fuel sensor. EGR also has to be dramatically pared back because without the TGVs the stock EGR map causes bad misfires. Now instead they have to implement the flex fuel system as a CAN bus sensor instead. IMO, this is heavy-handed but the EPA in the US gave so much leeway for so long and the aftermarket relentlessly abused that leeway to the point that they could actually see the effects of all these emissions-deleted work trucks on their air quality monitoring for cities that haven't met Clean Air Act standards. It's one thing to have a few people deleting emissions on their weekend car that spends 9 months out of the year on jack stands. It's another thing entirely for entire fleets of tradies driving around 8 hours a day on deleted diesels that emit 1000x the emissions per mile of a compliant vehicle.
    • Hmmm. that's a tough one. There's a lot of history bundled up in that lot. Perhaps instead we can create a new pinned thread, called "Legacy Pinned Threads" and provide links to the these ones that will be unpinned in there. And maybe put the names of the pinned threads that are linked inside in the tags so they can seen from the outside? Or something like? I mean, it's half a step back towards having a more complicated forum structure, without actually having it. But there's a reason that heirarchical architectures exist. They are logical, and if executed properly, make it easy to find something without having any upfront knowledge of where it would be , and without using a search function.
