yeah I needed to talk to you about the head setup again.
You definately aren't going to change to solids?
And exactly what turbo and housing a/r are you using?
looking like the garet 35/40 with .82 housing. Hi mount manifold.
Whats involved in going solids over hydro?
what is a 35/40?
and changing to solid (going along with the other valvetrain mods) will only require a purchase of lifters at around $500 for the set of 24 and around $150-$180 for the shim set to adjust clearances.
Means a much higher lift will be available to you and more durable for higher rpm/load
http://www.slidingperformance.com/catalog/...products_id=311
that one.
What sort of lift are we talkin here dan.
anything up to 10.25mm. Factory is 7.8mm so massive torque gains will be had. It's just a matter of selecting the right duration to match the turbo
That turbo is actually a GT3582R or GT35R for short. I can't tell you how much I can do one of these for as Col will get upset. He's probably watching right now so we should whisper. God forbid I save SAUers some money. Don't worry bout me...rant over
You are assuming it will be done some time soon.
Hey Shane....June is approaching fast.
What's the kitty up to now boys...$230?
its okay, atleast i'll have the satisfaction of knowing my car will be ready before yours :blink:
hey Shane, did you see the pics of the new giant 33. !SCHWEEEET!
indeed i did, i envy him and his wallet lol
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
