yeah, i blew a cooler hose in brisbane one day....when I first heard the sound I was pretty worried....lucky for me I had a mate that lived down the road as I didn't have a socket set with me at the time :laugh:
WHEEEEEEEE! YEEEHAH!! VROOOOOOOM VROOOOOM!! OH yeah BABY!!. GIVE IT TO ME. POWAH AGAIN AT LAST. VROOOOOOOOM
KABOOOOFF WTF...... FARKIN COOLER HOSE AGAIN.GRRRRRRRRRR.
walk walk walk walk walk(5kays) Gets socket set that should have been in the car. walk walk walk walk (5kays) fixes pipe. Opens glove box to put sockets in. AAAARRRRGGGGHHHHHH!!! 2 farkin shifting spanners laughing at me.
sigh
lol.. so noel any noticeable changes..?
and u get them from slide for 560 or whatever it is..?
yes its much better mark. I can boost it back to .8 bar where it was tuned. before the new coils it wouldnt run past around .5/.6 bar.
And yes, after much dicking around I did get them from Arron at slide. (the dicking around was caused by both sides so no argument there)
Hint for people who blow hoses alot (eg me) make the hose at the top of the engine bay looser than all the others...that way if it is going to blow it blows that one off and it is the easiest to fix :laugh:
lmao. Wouldn't it just be better to stop any of them from blowing off. 22 pound and the only ones that ever blew on mine were ones I forgot to tighten up.
Tip for new players would be to go to LHS and buy a bunch of decent hose clamps. They are still a worm drive one but have an incredibly durable housing which can be cranked down really tight.
They go for about 3-4 dollars a pop.
I blew a balast in one of my head lights (HID) and cant find a replacement :sleep:
The ebay user I bought the kit from no longer is registered... So i cant even buy a new one from her...
Looks like i might have to fork out for a whole new kit :P
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
