lmao. Wouldn't it just be better to stop any of them from blowing off. 22 pound and the only ones that ever blew on mine were ones I forgot to tighten up.
Tip for new players would be to go to LHS and buy a bunch of decent hose clamps. They are still a worm drive one but have an incredibly durable housing which can be cranked down really tight.
They go for about 3-4 dollars a pop.
To be honest it really is more a case of that is the one I most often undo and hence forget to tighten ha ha
Nah only you are enough of a tool to bother having a dig about somthing so dumb.
Umm how about this Shane....it must suck needing 800hp just to keep up with everyone else :)
sick, im a tool :(
i'd only need 150hp to keep up with you douchbags :dry:...sif i want 800hp, i only want 750hp :glare:
btw shane, sell me your oem turbo coolant lines. New ones are 2weeks away in japan. Ive found the leak now. And all i had to to to get access to it was remove the a/c compressor
which ones u need? half of mine are at mercury :)
Well. If you would come home at a decent hour instead of stayting out and SUCKing piss It wouldnt SUCK near as bad. :dry:
haha nah i was good to go to catch the 9:14, but i looked at my watch and it said 9:07, no farking way was i getting down to the station in 7 minutes :)
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
