Holy shit looks like you have been busy. You should have that completed by next week. HA!!!!!!
These coil overs mate, there is no were to adjust them as far as i can see, the rears have a brass cover over the top of them which does not want to come off unless there is a trick to getting them off.
But there has to be some adjustment because the ride is just to hard.
Also got some semi slicks yesterday. 275/35/18 Falkens AVENIS.
What are you doing today, do you want to look at this suspension of mine or are you to busy with your stuff.
the brass thingo over the top is dust cover for the standard item.. used on most newer cars.
Did the same thing with my ae86 shell. Ended up removing 30 kilos in sound deadener.
how u remove the sound deadner..? dry ice..?
was at noels all day mate, only just seen this & the pm now. depends what ur doing during the week, im home by 6 each weeknight...
Haha yeah its a task and a half isnt it! (who sprayed ur interior?)
I'm actually lucky i am doing this, because i've found 2 patches of rust, and its eatin right through the panels, both very close to the seams :rofl:. So now gonna get the inside seam welded just to be sure.
lol GTRs and rust lol... mine had lil.. and u gave me shit ahaha.. oh well.. ill laugh while i can.. for now my 180 is faster than ur push bike shaney poo
You have non damper adjust Teins then, which is pretty common. Non damper adjust come VERY firm/stiff unless they were ordered with a low spring rate, which sounds like your's weren't.
Best option for you is to just sell the Teins and buy some fully adjustable coilovers with a decent spring rate or some drag style coilovers.
pretty much the same as mine. non adjustable.. they are built for stability and to be very stiff.. the way drifters like them. :laugh:
dude im talking like a wanna be takumi with v-opt.co.jp stickers all over my car lol.. :thumbsup:
on the other hand guess who gets sparks from the rear tyres at the moment...???? yes someone we all know.. :ninja:
all ive got is the injector harness
troll the for sales and then ring the importers (all jap etc)
oh and edit ur sig, u DONT want to run a dodgey malpassi :domokun:
nothing wrong with malpassi.. had one on the GTiR.. yes i unplugged it and ran the standard FPR when i got it.. not the point.. it sat in my engine bay nicely. :sorcerer:
how are we whores..
im gonna go ring my tyre place and get them t stretch some 205s (skids better) on my rims.
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
