Ok i finally got the top off, what a f**ken challenge that was. I really needed some GIGANTOR'S. Now the pump, you say pull it upwards, but it doesnt want to move. How much force is needed, i dont want to break anything.
A bit of force is required. You need to reach down into the tank, grab it by the stem and pull up hard. Ask Shane, he can help with the stem grab and hard pull up. Lots of practice makes perfect.
I just got my car back from Peter Woodward, he installed the injectors but thanks to you know who you are, the bent rail gave him hell, he also setup a water methenol injection system that he is trialing in 3 other cars at the moment, it made 360rwhp on his dyno :D I will post up the chart when I get the chance, probably sat arvo. He tells me there is more in it but i wanted my car back because it is just too damn cold to ride the bike to Carol Park like I have been for the last 2 days, I thought I had frost bite this morning BRrrrrr.
I'm STOKED for both reasons !!!!1!!!
im gonna sue, caus that there is defamation...:)
ooooor u could just unclip the cradle and lift it out, but hey its upto you :banana:
maybe u shoulda just stayed with the non-bent one :banana:
sounds good terry :D
Ok jackpot fellas, i finally got the bastard out what an operation. Its easy now when you know what to expect.
Ok now the problem is what type of fuel pump to put in. It looks like a nismo pump i just pulled out.
Should i go Bosch 023, Sard, Tomei or Nismo. I just want to keep in mind about future mods which will be aiming for around 400rwkw.
im gonna sue, caus that there is defamation...:laugh:
It's only defamation if people care about you Shane. You need friends first.
Plus I'm only stating facts. I knew you would be able to help him get it out. You are 'THA MAN'
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
