Yeah 100% the actuator mate, dropped the exhaust and took the car for a spin...sounded tough but boost still faded away.
Putting a bellmouth dump on tomorrow in the hope to equalize the back pressure accross the wastegate flap and stop it being blown open by the low pressure that's currently sitting behind it (the split dump is split too well)
Possibly but I doubt that is your problem.
Did you say the turbo only made 15psi with no vac hose attached to the actuator?
Have you taken a boost reading from straight after the turbo and then another one from before the t/body, then another one from after the t/body?
If not - do that.
Skyline is basiclly sold now... :thumbsup:
Got a car yard to put an offer on it, so now I have a week to try and sell it for more however I dont think it will as everyone are tyre kickers these days...
Im asking a grand more that the car yard has offered, and its gonna cost a grand to put it through road worthys and mod plates...
So im not holding my breath...
Thats a pretty good price from a car yard.
In this market i would take it. Like you said a lot of tyre kickers about.
Skyline is basiclly sold now... ;)
don't take this the wrong way, but all that to achieve 300rwkw and not to really use it?
like you said, there's a valid reason: owning too many cars and hardly driving it.
and i'm speaking generally here; but doesn't anyone plan things anymore?
why i want the skyline?
what i want to do with the skyline?
how am i going to achieve the above?
just seems a shame that's all. alot of hard work and no enjoyment.
If not - do that.
lol yes, and the fact you can watch the actuator open while on the dyno is a bit of a giveaway. I'm not your typical SAU n00b Dan ;)
howly dooley you boys get active at night!
ok this is the best I can do for you:
Had the car for 6 months, purchased from dodgey import yard. 90,000kms on clock Possibly original timing belt - this worries me!
Fully stock trim apart from turbo back exhaust and apexi pod filter
Car has always run like shit when cold cofs and splutters when you give it a bit of gas has been known to stall from time to time
when accelerating it will sometimes misfire and backfire
Has started to use lots of fuel recently
On sat night we went for a spin, driving the car hard once it was warmed up was going nice
Launched the car from the lights apparently did not feel it had as much go as usual - kept pushing anyway
Drove at normal speed for a couple of km
Decelerated to a set of lights
Engine cut out
Refused to start
Would not turn over
basically just: kik kik kik kik kik pop pop kik kik kik kik pop kik kik kik - pit of smoke coming from exhauste - not puffing out more like smoldering out
RACQ Checked:
Fuel pump - good
Alternator - good
Dizzy, Leads - Good (Changed leads last service)
Oil good was changed Saturday morn with Royal Purple and KnN Oil Filter
Apexi Air Filter was cleaned and re-oiled on Saturday morning - he is woried he put too much oil back in as there is a little dripple of oil in the bottom of the induction pipe - should this be cause for concern?
Found the plugs to be soaked in fuel after trying to start it so engine is getting fuel - mabye too much?
feels like maybe a computer issue or another mate reckons he snapped his timing belt - this idea was thrown in at around 10pm last night and has not been checked yet, will keep you posted
is it normal problem for gtir to run like shit when cold?
thats the best I could do as its not my car but I have a decent understanding on how its been playing up!
Thanks again markimak!
if the timing belt snapped, the motor would be completely shagged, i.e valves contacting pistons = valves through tops of pistons :glare:
GTiR use timing chains. and ther will be no crank over at all if the valves are hitting the piston.. i might come have a look wher u located..?
the timing chain is alot stronger (opinionated) than T belts. and dont need changing.
check how much oil u have. perhaps ur mechanic forgot to tighten the sump plug and ur oil leaked out.
sounds like its cranking over. so im guessing its gonna be no spark. they check ur ignitor.? get a compression test
all cars run shit when cold. its just they run a different map and have the auto choke on. u shouldnt drive a car hard untill it reaches operating temps.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
