ahaha..ok..
hmm tossing up the idea of buying a a/m FPR or seeing if the standard one works with 740cc.. which sound be flowing 60% at 200 but im going for 240kw. what brand.. had a malpassi before.. not impressed.. perhaps sard..?
perhaps ill try with the standard..any suggestions
The only downfall of the standard reg is flowrate. I think they are limited to 230L/hour or 600rwhp
Why have you picked 740cc injectors? They can easily supply you with enough fuel for 500rwkw. 240rwkw should only require 550cc and even then you won't come anywhere near their max. It's all in the tune. Get youself a Nismo, SARD, HKS or Tomei intank pump (they are all the same pump). They are the best for direct fit and good for up to 550-600rwhp
went for a run round nebo in one fridy nite, farken impressive
P.S shuddup andy :laugh:
the low down pick is unbelievable, comes on boost soo quickly and they rev fast as
they have great torque
Im still buying one as soon as I can sell both my cars
yeh do it
i dunno if i like the way they ride/handle though. it feels as though they are forward biased, and the center of gravity is too high. spose that can be all fixed with some suspension mods though
yeh do it
was it an MR??
EG carbon fibre rear wing and not just the blade the Whole thing
The MR has Bilsteins suspension and an aluminium roff to negate that effect you felt
what they say about the GT? Is it motor with the new M3 on the cover?
YEAH TEH ONE WITH TEH M3
that is will be a 5.4 litre v8 with 320kw BUT THE MOST UPSETTING PART WAS HOW UGLY IT LOOKS NOW :laugh:
was it an MR??
yep it was an MR
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
