mineral oil marki, best stuff for diff's apparantly :D
apparently.. yeah heard bout that too.. was gonna go castrol as im a castrol man. but heard some shit with castrol and redline in cuscos.. so i got 2.5L of penrite coming.. short notice shit.. 80w-140 should be fine.. will change it every 10kms.. :)
any other suggestions guys
no but im serious was told that i should use not synthetic on cusco diffs.. as it shudders with synthetic..
meh penrite it is unless i can find some redline cheap.
The shuddering can be corrected with an additive that redline also sells.
You should only need 1.5L so 2 x 1L bottles is all that is required. $60 and you're sailing!
howdy all,
week end is over :P
got myself a nismo short shifter and a Z32 today and marki - :)
shal be good getting it all in, im over the hks manifold idea now after talking with murnane again on sat they reckon slap the biago internally gates sucker on there and tune, cause it should keep me happy for a while
its solved guys, basically we were discussing if my mate with a gts4, could simply remove the altessa pump fuse to allow him to slide corners and do burnouts...
was intersting and went gor a while
Redline at any price is cheap you tightarse.
im tight.. pretty sure students dont go out and buy 700 diffs like that..
y not buy some of that cusco oil then? 90 bucks for the bottle isnt it?
wher is this from.. im keen... found kaaz oil..
think ill go to autobarn tomorrow. wher do u find the oil u speak of for $60
howdy all,
week end is over :(
got myself a nismo short shifter and a Z32 today and marki - :D
haha great. how much u pay.. yeah i dnt need the Z32 yet.. think ill keep my 160kwish for a while.
nice eh.. ther is a N-S mounted 4G63 in a EVOIX in japan. designed for drift.. no more AWD.. kinda pointless i think
got it of 666DAN for a great price, getting his gauges too when he gets a chance to pull em out. he said you were trying to get it but i had already given the word... timing my friend!
if i only had a doller for every time i saw a deal on these forums im usually too slow to act.
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
