Just to clarify, different times of day can present better or worse cooks. The Norman for LUNCH on any weekday is my no.1 pick.
1. Norman (lunch - weekday)
2. Morrison (Dinner)
3. Pineapple (maybe 4th)
4. Bunta's BBQ (should be 3rd)
5. Regatta (Wagyu only. )
Now remember you said Brisbane. Spotted Cow kicks all their asses!!!
Id be confident in these are 5 of the best places in Brisbane to get a steak, but in no particular order and im sure there are othrs just as good.
But here is my 5;
1. Breakfast Creek Hotel
2. Marriot Brisbane City (Eagle st)
3. The Norman
4. Warner Tavern
5. Hilton Brisbane (next to the embassy)
Out side of Brisbane but still in QLD (need 7 spots as they are all top notch)
1. Fibbers in Toowoomba
2. Spotted Cow in Toowoomba
3. Wide Bay Tavern in Hervey Bay
4. Royal Pines Resort on the Gold coast (The dinning room on the 21st floor, dress code applies)
5. Kawana Tavern, Nicol Way Kawana (lunch steaks to die for)
6. The Villa Hotel in Noosa
7. Villa Remano in Cairns (Reef and Beef is meaningless until you have eaten here)
country towns are always good for steak - just gotta get the right person to cook it
had a 400gm rump my first night out at dysart ordered it medium rare - it was definately medium to medium well but could tell it was good quality so i had it again the next night orderd it rare and it was what i would call medium rare and was lovely
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
