hmm, dan can u recommmend any places for exhausts?
and do you think its beeter to go buy a full turbo back zorst, then go to a palce, of let them do it all?
It really depends on your budget and how much power you want to make.
If you have a bit of money, buy a CES dump pipe and CES catalytic converter. Then buy something like a Trust exhaust cat back system and just bolt the thing up.
Kakimoto are pretty much the only available exhaust system that is available for your car that can be delivered. A cat back system is approx $880. The CES dump, cat and custom 3 inch system that I did on another 34 netted him with 175rwkw on an otherwise stock 34.
The CES dumps I think I can buy for $500 and not sure what the cats are worth but they are a slim profile to fit under the 34.
Regards, Daniel
I need to stop doing so much work. I need to get my car back on the road. Nearly have all the bits to get going. 800rwhp should be enough I reckon.
But then again I might add some blue bottle throttle as well.
anyways Im gonna go do my oil change im heading down the coast in the morning
hey marki i have heard some shit about not regapping NGK iridiums but i have got a bit of misfire since i put em in and the previous plugs just ngk coppers were gapped down to.8 with no dramas
are these iridium things ok to regap?
why dont u ask matt.. apparently i knw f**k all bout cars.
what gap are they now. if they are .8mm they will be fine. just a boosted car normally blows the plug spark out. it does on my ld gtr and on a s14 i worked on today.. put some .8mm gap ones in a no missfire.
ive gapped platnium and iridium with feeler gauges and work fine.
just dnt be too rough
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
