I made soup
i had tuna pasta.. but lunch i had a deluxe burger at sizzler.. and it was good and fatty :domokun:
i need to start looking at puting together a motor on the side as mine prolly wont have much left in it once it is boosted
is it cheaper to do a 25 or a 25/30?
lets just say i already have a spare head and a choice of either block
its going to cost about the same to pay a builder to put either package together rite?
and approx the same for all the parts: forged pistons, rods etc.
i would guess the 25/30 will be more expensive as i think the oil lines or something dont line up proper with the head.. dnt knw exactly nor do i care.. SKYRINEs lol
much of a muchness really....might cost more to match the 2 together with a 25/30....but will get more power from building it, then a 25....be about the same strength i guess.
drop shanef a pm he is building one. he will know
hi rohan
sarp marcus
yeh but the thing is its going to be preety simmilar price really and at the end of the day the 25/30 will be more fun and have more potential
I shal take pics of my sausage for you all
Evening all
yo homeboy!!!
touche....depends if you want it or not i guess...i am just going a slightly bored 25 block and flowed head, cams etc...blah blah
should be nicely noodled
Joshwa....whats wrong with tuna??
link dont work <-- dont listen to him....farken does now
on that bombshell i am going to bed...
need sleep
cya in my dreams boys......mostly you nismoboy...you cuddle bear you..
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
