Yeh it's not really worth it, but it's some funny shit. They're mostly crazy monster girls that beat the shit outta the guy or other girl before they sodomise them with sharp implements :D
I've put a ban on myself... i'm not watching any more until I find my favourite one... it's gotta be on one of these discs :D
Is that the dry humping one!
yes exactly...makes you realise how good real pron is.
so anyone knw wher to get season 5 in englsih manga?
no stop asking.
or search www.isohunt.com
and get the torrent.
$1000 eh? :D each? ....... :D
I want these rims.....
they are volk GTCs tim i can find a nice set in 18 for around 2600-3500 dependin on colour
they are my fav ;)
I am so bored... I am so bored... B-O-R-D... I mean B-O-R-E-D
get a job.. or talk to me on msn ;)
bullshit, ur black u can strip and car in 5mins
ahaha.. im doin a turbo on the S14 now.. hopefully the head gasket is fine :)
bahaha....how about i swap you for a geniune set of 6 gtr r32 rims...with tyres.... :D
but seriously...dont sell em for less then 3500
yeah ill get that huge off you soon....just make sure you get in there nice and deep boy.
yeah 3500 is lowest ill sell them nismos for!!!..
oh well 8 mins is up my pasta should be done.. now for the sauce ;)
Nice choice of rim Tim. hotness. i havent found a fav of mine...which is why i would stick with a dorifto tek.
actually i have now...the Work XT7 mmmm nioce.
Sif dry humping old man. Anyway after last night i'd dry hump anything, I had a blast!11
bahahaha
I laughed then
so did i.
i dnt drive no stagea.. bahaha
not funny
uh-huh. do you like it when it's got a story line or you prefer it to cut to the chase?
I laughed then
Don't laugh at my perverted self :D
:D it wasn't you... he was cuter :D
JK wubs you ;)
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
