hmm i was in a toy shop today, and i almost bought some initial D toys :whoops: like 1;10 scale ae86 and rx7s etc :( 199 Ringet,
and i almost bought a 1;20 scale rxy which coems stock, but has parts included, liek front and rear bumper, side skitys, fake carbon bonnet, wing and decals and rims, and exhuast system lol all changable.
then i grew up and left :)
Check this out.
Sorry, didn't work.
And BTW, SARD injectors are one of the best injectors on the market. Just because they use collars on RB25 doesn't mean they are shit. RB20 and RB26 (decent engines) don't take collars. I would buy a SARD before a HKS or Nismo. Unless you have an RB25, then buy Nismo.
thats because thet are f**king POV spec
anything that is good will come with new seals Liz
NISMO FTW
I smell emo
hahaha
Insecure much?
nope just a good comeback i thought.. peace col *hugs*
Trying to find a tint shop who will tint the holden this weekend, but their all booked up... :whoops:
Dont really care how much it is, just want a tip top job with good quality film...
thers a mob next to ABS at the gabba.. best job ive ever seen.. we send the toyota cars ther
u suck at whoring
u suck.... FULL STOP
Check this out.
Sorry, didn't work.
what do u recommend for SR20s i think they need collars for the SR
yes Marki SR's are side feed too, same as RB25's...
S15 have like 470cc injectors, so it could be a cheap upgrade for an rb25, however when i was in the market it was hard to get a set of 6 as everyone wants to sell 4.
Plus for the money I was able to buy a set of 6 nismo 550cc units brand new, which was far more fitting to my application in the end...
BTW Do you have a name for that tint joint???
I think only JDM s15s have that size injector
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
