we just looked a no 1 ...and the bearing had some nice wear marks....like .5mm deep.
crank was fine on no 1 though...didnt look at the others. Dan had to go.
yeah sif you wouldnt remove the slave cylinder.
come out easily
woulda saved about 15mins if someone removed the clutch slave cylinder before we tried pulling the motor out :(
bahahaa..
yeah ill say it had some marks thru it.. looks like a grinder got to it..
sif not run it til it knocked! hahaha
thats how ur engine die..
went to repco this morning asked for a 445 oil filter for SR.. knowing that the ryco ones are around 11 and she takes 10mins to find it even with me givin a part number and tries to charge me friggen $21 i say uh NO.. genuine is friggen $10 but a fair drive.. so ill get genuine filter sometime this weekk..
REPCO IS GAY
RIP EVERY POOR c**t OFF
Good morning from Mildura!!!!
tEAM eT represent!!!!
Aww its so stock mud! What you doing to me!!
you need some HRE's http://www.hrewheels.com farking like $10kUSD for 18's or 19's :(
Then we'll put some KW coilovers in for ya http://www.kw-suspension.com
rivers just rang.
497hp. dunno what boost and i'm assuming 8500rpm.
thats with the cat still in place, mick just pulled it all apart and found leaks everywhere.
mite take some vids tonite of how it pulls :(
rivers just rang.
8000 rpm. not sure of boost yet, Just waiting for an answer
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
