I dont know!
They caught the people after the fact in their car after a short chase! The cops were given the numberplate by a witness who gave a statment saying he saw the people in the car with xxx xxx number plate jump out and jimmy the lock and start rummaging through the car, the crooks then admitted to being in posession of our stuff and they admitted to being in our car cause they told the cops that they had our permission to take the faceplate. We then said that no one had such permissoin (who would give someone permission to damage their car getting in...wouldnt we have given them the keys?)
So im not sure waht the prints will prove..they already placed them selves in the car, they admitted it!
Anyway you would think this is an open and shut case but apparently not
ahh man thats ghey, hope you get it all sorted out bud.
RUF *drowl*
rb20 limiter is higher then a stock rb25 isnt it?
well my car is done but the police expect me to pay the $270 towing bill and be happy about it...letter to the minister coming up
what!! i wouldnt pay it man.
was it your 32?? or 33?
RUF *drowl*
Think pumped N/A track built motor, think stupid cam size’s, think somewhat biggish webers for a street car, think duel 3.5inch exiting exhaust's on each side, think foot long + flames out each bank coming off wide open throttle.
Was a fun, fast car. However was "rough", for a RUF. Was a driver's car. Dads current one is nothing more then a fat stock brokers car. I think he is getting old.
Are you f**king serious, take the people who broke in to small claims.
Im thinking the police department will pay
A. it was their fault because the fingerprinter was not available
B. it was their fault cause their tow truck was not available
C. they told me it would have to go to the impound, they didnt give me any other option
32
f**k
dam straight they should.
There is nothing like a hard tuned N/A porsche....mmmm...
A strongly worded letter will fix this :spank:
For sure, I actually don’t like the sound of turbo Porsche’s as much (as do most 911 nuts). It’s weird, seeing most cars sound better? In turbo form.
Something about a hot as N/A flat 6 note, in fact most N/A euro’s make me froth with there exhaust notes.
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
