no coilpack cover ftw :) or HKS war paint!
cant go no coilpack cover cause my coilpacks are red and it will f**k with my equilibrium of blue/pink/polished and the loom looks to messy anyway
before i start...f-off shane!
do you reckon I would have much trouble selling brand new in the box hks step one cams for rb26?
was thinking trying to sell for $800 Delivered Aust wide - they are on Nengun delivered to bris for $812 and slide has them for around $1200
u called? :worship:
depends what size they are. im assuming theyre nothing overly big. u can only try mate.
u do realise greenline do tomei cams & cam gears for $760? :)
awesome i just won my ebay auction - new silicone radiator hoses $62 delivered!!
should go nicely with my new alloy radiator, hks cam gears and hks belt - rice ftw
now to polish the plenum and cam covers - trying to decide between custom coil pack cover or paint the oem one hks pink - just for shane!!
hks will suit ur riceness and ur passion to not go fast quite well, so yes, paint it the hks colour, remove ur cam cover and show them hks gears & belt with pride!
:P
P.S love u long time daniel :D
What should I get for lunch?
A bish
hey bish
welcome to my world :worship:
lol yeah its groovy.....just getting prices from greenline atm...seeing how much it will come to for a few items...and waiting on a few other bits as well atm....well see when they arrive.
I don't work in fyshwick so i can't get a bish.
I think I might get 2 lunchboxes for mthe asian takeaway.
Or maybe subway.
Possibly oporto.
Go asian it takes better....i am talkin about food this time.
wierd tho I was never notified that i needed to pay or anything then im told i havent payed and membership is suspended - would be nice if your told to pay by xdate then if you dont pay suspend membership
/end rant its not worth it lol
I shall just pay the man!
mroe bits on their way
:huh:
details
maybe, prolly partly our fault too caus we should know where in the year we joined *shrugs*
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
