whats sarp is i got these fuggin lairy pink cam gears now i go reald all this bultch about not to use em on the rb25
doing my timing belt on the weekend so should i put em in or not??
i hope u only got 1 cam gear, caus on the rb25 u can only run it on the exhaust side
and yes, put it in and get it tuned
you can use one on the inlet side. just removing the vct in the process.
huh im outa the loop whats going on?
oh and marki the jjrs are just as good as the splitfires imho they cant be that much better I would have to see cold hard evidence that the splitfires are better before i believed anything + I got the jjrs for $300 so you cant really go wrong
serious do they do R34 GTT neo yet. i need another set of coilovers for the RB25 as i sold the last pair was gonna go splitfires.. but why not JJR. i reckon i can get cheaper than 300 too.... call to dan will fix that. ive only brought like 20damn things from JJR and still no discount!! :thumbsup:
pink cam gears... WHat tha???
translation = YUM YUM
VCT is good
so is ice cream...
no vct makes noises and hinders upper performance later on. well on SRs they do.
whats involved with removing vct?
crowbar. mine is called gloria.
i remember soemthing about welding up an oil hole...
if you search FIP area there is a thread i can remember
its not worth doing unless ur going to put in decent sized cams, port work & bigger valves
soo much farking around for a simple fine i wonder if they will go thru it.
the prosecuting officer has leave during holidays so its been adjurned till 7thdec for me to send a letter with my evidence before then. and the officer gets back early feb haha lets see if he wants to go thru it.. i doubt it. but fark i gotta do all this printing make a letter. soo time consuming.
in the end i win. cop lose. well government actually and im keeping my $375
this is ghey i was so excited about my new pink bits
can you even run a 25 without the cam gear cover anyway? Im getting the sinking feeling I didnt think this impulsive buy through lol
Edited by dano4127
yeh u can. u just gotta put a spacer in behind the CAS to imitate the thickness of the cover, or ur CAS wont work properly.
u know how to set the new timing belt up properly?
that collection of cars shane is f**kin amazing...
The old DR30 looks the bomb... :rofl:
ur telling me!
my jaw was on the floor for about an hour while i drooled over the pics! couldnt believe what i was seeing! :wub:
everything nissan is in that building.....road trip? :D
http://www.skylinesaustralia.com/forums/t1...b25+timing+belt lol wish me luck! :sorcerer:
guidence people - cause i always seem to get myself into trouble:
PFC Boost controller New in box $200 posted to brissey
are easy to play with on the comander?
i assume so, never acutally played with one.
my philosiphy on ebc's is that if u can get one that bundles with the ecu then itll work better than a stand alone
VCT is good
so is ice cream...
but you also out grow it.
head needs to come off to do it properly
myeah i can do that
i just had multiple orgasms....
what is that R32 with that VQ in it...it looks factory!!!!!
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
