this is ghey i was so excited about my new pink bits
can you even run a 25 without the cam gear cover anyway? Im getting the sinking feeling I didnt think this impulsive buy through lol
yep.. but do u like shit going down ther..??
yeh u can. u just gotta put a spacer in behind the CAS to imitate the thickness of the cover, or ur CAS wont work properly.
u know how to set the new timing belt up properly?
thers a proper way..?? oh do tell im interested.
/subscribes
Yeah i loved the 2 x 350z's are the start and the red R34 GTR GT500 car... OMG
The first Z33 was pretty cool also, chassis number 000001
The old silvia box car, le mans style looks funny, and ive never heard or that 390 gt1, probablly cause its the only one ever built...
haha yeh its pretty straight forward
tips - before you start, make sure uve got it on TDC ( u can check for tdc by lining up the 2 white marks 1 on the harmonic balancer the 2nd on the lower engine cover), and dont go moving the crank or cams when u remove the belt
guidence people - cause i always seem to get myself into trouble:
PFC Boost controller New in box $200 posted to brissey
are easy to play with on the comander?
can i buy from u... wher u find that.. wouldnt mind one for the 180sx
i assume so, never acutally played with one.
my philosiphy on ebc's is that if u can get one that bundles with the ecu then itll work better than a stand alone
only if it interfaces..
im almost certain they interface with comander as thats what you use to set bost change shit around
I will sell you V1 AVCR for $170 :D
whoretown goes off on on fridays aye
:D
yes shane :rofl:
could that even be possible?
not sure, hence why i asked the question :wub:
I will sell you V1 AVCR for $170 :)
dont listen to marki, he'll just confuse u lol
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
