Whoretown - Now Interest Free
Squizz
What if you test positive a day after smoking when ur not affected by it at all?
I think its a bit confusing that nothing is being stated, not how long you would need to wait, not a level like .05 etc
seems pretty bs to me
fixed my sig just for you shane!
haha noice :P
well seeing as drugs are illegal (opther than presciption) showing a positive reading of any sort should mean fines of some sort
i would have eaten enough munchies by the next day to dilute the shit down lol
but yeh i do see your point, get stoned at like 8pm bent for coupe of hours fall asleep wake up in morning sweet as, get done for the green
I had my hose on for 5 or 6 hours the other day topping the pool up.
haha easy for u. my pool water has dropped 40-50.563cms over the months.. please rain heavilly
daft punk. i always picture them as the evil doll thing from technologic
Thats just Eug and Mudcrab trying to disguise their gayness. :P
... im banking it this wednesday night noel. cya ther. in my gayness im bringing a integra type S FC Rx7 and some silvia. unsure which one.
the aftermath
my room
more flooding
My sucker...(best blow job evr)
Satanic blind...
shit... thats gay what u tell the miss's she still overseas.?
you don't know who daft punk is?
woah, that is really random with the water tap.
noel is too old to knw.
hi carl :ermm:
dont make plans for wednesday nite alrite! noel and myself are goin out to willowbank and ur coming!
wat do u think the chair will run.
i just want a 13second run of anysort.
Yes i do... I remember listerning to them when i was like 12-13...
Was cool to have a walkman :thumbsup:
oh, i was just going to say that; everyone should remember growing up with them.
i remember getting my first walkman, you're right it was cool.
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
