fixed my sig just for you shane!
haha noice :P
What if you test positive a day after smoking when ur not affected by it at all?
I think its a bit confusing that nothing is being stated, not how long you would need to wait, not a level like .05 etc
seems pretty bs to me
well seeing as drugs are illegal (opther than presciption) showing a positive reading of any sort should mean fines of some sort
i would have eaten enough munchies by the next day to dilute the shit down lol
but yeh i do see your point, get stoned at like 8pm bent for coupe of hours fall asleep wake up in morning sweet as, get done for the green
I had my hose on for 5 or 6 hours the other day topping the pool up.
haha easy for u. my pool water has dropped 40-50.563cms over the months.. please rain heavilly
daft punk. i always picture them as the evil doll thing from technologic
Thats just Eug and Mudcrab trying to disguise their gayness. :P
... im banking it this wednesday night noel. cya ther. in my gayness im bringing a integra type S FC Rx7 and some silvia. unsure which one.
the aftermath
my room
more flooding
My sucker...(best blow job evr)
Satanic blind...
shit... thats gay what u tell the miss's she still overseas.?
you don't know who daft punk is?
woah, that is really random with the water tap.
noel is too old to knw.
hi carl :ermm:
dont make plans for wednesday nite alrite! noel and myself are goin out to willowbank and ur coming!
wat do u think the chair will run.
i just want a 13second run of anysort.
Yes i do... I remember listerning to them when i was like 12-13...
Was cool to have a walkman :thumbsup:
oh, i was just going to say that; everyone should remember growing up with them.
i remember getting my first walkman, you're right it was cool.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
