Whoretown - Now Interest Free
Squizz
there are 15 collin bakers on facebook!
why no facebook col? no time?
There is always time Dan...
Just dont like the idea of all the nerds from school getting in contact with me...
I ditched my re-union cause like i wanta hang out with a bunch of mofo's talking about how many babies they have had or how much money they earn...
I know im better than them :cheers:
That and im in a 7 year relationship and i figure facebook/myspace as being a bit of a dating service...
I think we're having one soon, I am not going lol.
You know, your right about myspace. I've f**ked 3 people off it lol. It's cheaper then adult match maker lol
ps my name is spelt with only one l
as are most people with the name Colin in this world... :cheers:
Only chumps call their kid Collin with two L's
Be liek spelling Daniel with two N's
Normally the first name Colin is spelt with one L (Ie. Colin Citizen)
Then surnames are spelt with two L's and end with an S (ie. Jacob Collins)
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
