Whoretown - Now Interest Free
Squizz
lol hey thats the highest post count i have on any of the forums i frequent
that being said what other forums do you guys use?
I use them all, although i post the most on this one.
ns.com
pf.com
bc.com
and other car ones
And a few american car an non car forums
computer is giving me the shits: Anyone know why all of a sudden when i save a file it defaults back to the "documents" folder rather than the folder you have been working in?
why its sucks is i make a document then export a pdf for client approval and every time i make a pdf it defaults back to documents folder so you need to navigate back through the folders to the client folder your working on?
make sense?
its shit and takes up my valuable time.
u need to edit ur adobe pdf printer driver
load up adobe, open a pdf file, go to print, select the printer as "Adobe PDF", hit the properties box, under the "Adobe PDF Settings" tab theres a dropdown for "Adobe PDF Output Folder", hit the browse button to the right and selcect the location u want it to default to. hit ok and ok again and then it should be set.
thanks shane
I don't think that will work for me as I'm not really "printing" pdf's as you would in most other applications I am using the pdf export feature, and this is happening across the board not just exporting pdf's its saving / save as
if you creat a file save it in a folder then wanted to save a copy of it you would "save as" usualy it would default to save the file over the one you just created as it would be going to save in the same folder - mine is constantly defaulting back to the "documents" folder
AAAARRRGH!
otherwise, just make a copy of it in the same document, and grab the scale tool and scale it up to match,
or jus work out 35% of the original dimensions and then enter what the original dimensions would have been for the small image
BAH...what program are u usin..
Edited by RusH_
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
