Whoretown - Now Interest Free
Squizz
I think I'd probably get the same times from their cars with stock brakes. Car setup is not just a lot of power and massive brakes. But then, what would I know? Maybe I wasted all those years racing, engineering for race teams and swinging spanners in pits. Since Russ is running parts I manufactured in his 32 I probably could have a realistic discussion with him Col. And I've recently been discussing setup with Nathan.
So why do you think they run the brakes they do in V8SC Col? Seriously. I'll tell you if you have it right. Think predictability..........
Someone with a massive brake setup took my GTR for a drive yesterday. Strangely he thought it was pretty damn good, and yet, since it is just my road car and not my dedicated track car I know there are deficiencies in the brakes, and the tyres.
Gervasse, I just took a look at that silver GTR. It would be pretty reliable with a bit less peak power. Steer clear of anything with Teins unless you intend to dump them. They really are a poor product. If you really want a decent track beast then there are much nicer suspension setups,especially if you're considering spending a lot of bucks on a high power car. Feel free to catch up for a chat anytime mate.
Yeah, those Brembos on Noel's car pull up like shit!
Sounds like something I would like to see.
But yes, both of you are right...I think the stock brakes on a Skyline are over engineered for the vehicle but that's what makes them so great. Obviously they have their limit. There is no arguement here....you simply CANNOT do everything with the factory setup.
Plain rotors and factory sumitomo pads WILL fade after the first couple of laps.
Having said that, though, there are things that can be done to the factory brake setup to improve them out of sight. Slotted rotors and a better friction material do wonders. I've had to talk Benno out of going a Brembo upgrade because it's just not required IMO. In most cases the factory calipers are doey and most of the rest of the system is old and worn out too. Take yourself back to when the vehicle was brand new. You would not believe the stopping power they have.
Driver experience has much to do with it also. Slap a 17 year old kid fresh out of school into the drivers seat and watch the braking technique. An experienced driver knows how to brake later, harder and with less heat transfer so, therefore, can utilise the brakes for a longer period of time.
Race brakes have their place....and on a street car is a bit of a wank seeing as though the factory calipers are well capable. But there is also nothing WRONG with putting race brakes on a street car. Your car WILL have more braking potential but wasted potential if put under the foot of an inexperienced driver.
Sorry Col, that time I was actually being condescending. You shouldn't try so hard to make it so easy for us. :) I was talking about the QR 6 hour.
I'd run in a 12 hour on stockers in the GTS30tt. There would be a 15min stop for pads along the way.... maybe even a second. At the 6 hour this year I'm trying to get all the stars to line up and run. Otherwise maybe P1 Supercar Club might sponsor me in a Lamborghini or Porka.
The reason the taxis use the callipers they do is so they can do a pad change mega early in the pad wear range. This stops piston rock which can make it hard to drive the pistons back in for a change or to knock off slightly after an application. Their pad thickness is massive just for that reason.
I have to admit a nice package looks good, but for 98 percent of people using them they are not ever going to work to capacity. I have a damn fine document that demonstrates incredibly well the difference between a set of stock Impreza sliding callipers against a range of upgrades, including a set of F40 Brembos. Amazingly the F40s didn't do that well over the course of 20 hard stops.
Ahh, Dan. Someone with a clue. Thank god. Actually I would not run a proper race setup on the roads in a daily. The temps are too hard to maintain for the pads. Otherwise, it will work fine but seriously wasted. And a heavily sintered pad will also chew your discs to pieces if you can't keep the temps up.
Hi Anna!!!!! :)
Weather, ignorance, 3kmh tolerance, wankers, GayFL, miserable one day, sh*thouse the next, metros, hammered with canaries, the list goes on. Feel free to check it out Josh :ermm:
Despise Vic. Except for SAUVic.
Weather, ignorance, 3kmh tolerance, wankers, GayFL, miserable one day, sh*thouse the next, metros, hammered with canaries, the list goes on. Feel free to check it out Josh :D
Im a born an bread mexican :)
brought up in Mt eliza, spent the weekends at Portsea. Your right though with what you say. But it is pretty appealing to my age group :ermm:
Bull f**ken shit. :D
There is nothing at all appealing about Vic or NSW (cept SAUVIC and SAUNSW or course). They are merely crap holes you have to step over to get to anywhere decent....like the antarctic.
Weather, ignorance, 3kmh tolerance, wankers, GayFL, miserable one day, sh*thouse the next, metros, hammered with canaries, the list goes on. Feel free to check it out Josh :ninja:
sounds like a nismo boy wet dream!
Big brakes are just a wank.
I was thinking of these cause they match my BOV and Cam gear colour schiem:
http://cgi.ebay.com.au/D2-8-Piston-Brake-k...1QQcmdZViewItem
Edited by dano4127
Shake and Bake Shreksta. My thoughts entirely.
Dan, those are a decent price but you get what you pay for. 2 piece design and not extended far enough around the disc to allow an extra stud each end to prevent flex due to the pistons being set well within the line of the existing studs, just past halfway. Pretty and great to go with a colour scheme, but I wouldn't buy them myself. I certainly wouldn't race on them unless I had a full spec sheet with piston sizes to calculate the balance, knew exactly what pads and rotors fit to see what the costs will be and know what the swept area will be on the disc, even if they were free sponsorship product.
my point exactly!
AFAIK the D2's are replicas of the AP's so probably manufactured offshore and riding on the back of AP R&D to give the cheap price
I am fairly happy with the brakes on my car now just did new lines, pads, fluid, slotted rotors and caliper kit - huge improvement over the neglected warped discs / shitty pads that were on it when i got the car.
Bull f**ken shit. :P
Food, fashion, entertainment, lifestyle. That is all
    • Quick update team on the build Things done. Installed Diff Brace ( TMR Performance ) Removed Steering Rack and replaced bushings with GK Tech bushings Remove Manifold and replaced Rocker Cover Gaskets and the Spark Seal Tubes Installed 1000CC Bosch Fuel Injectors Installed R35 Spark Plugs ( Pre-gapped to 0.28"  Installed Z1 Coilpacks Removed Fuel Sender unit and modified OEM pump to fit the 350lph Fuel Pump Installed Fuel Sender unit back with a Fuel Return system ( TMR Performance Fuel Return V2 )  Setup Fuel Lines that were AN lines and used P-Clamps to secure them to body ( This is needed to make this road legal in NZ ) Setup Fuel regulator Setup Vacuum lines from Wastegate to boost controller ( 3 port mac valve ) Wired boost solenoid to the EVAP sensor ( Behind manifold of car ) - Polarity of cables doesn't matter Setup BOV and Fuel Regulator lines Installed both aftermarket Aero Fenders ( Sourced from Japan ) Received Impul 280km/h Speedo ( Sourced from Japan ) Installed Carbon shift console Drive down the road untuned without creating boost pressure to test for leaks ( Video attached ) Setup JRP Racing 14in1 Gauge with Boost pressure being monitored Buttoned car back up and Tow to tuning shop in the mighty DE ( Nissan Elgrand E51 ) - VQ35DE Tuning platform is EcuTek and am hoping to 550WHP ( Dyno day is 9th and 10th of October )  Had Shop weld in a new Exhaust piece to connect Downpipe > Motordyne Resonator and to add x2 02 Sensor bungs for an AFR Gauge that will hook into the JRP Multi-Gauge    20240927_181518.mp4 20240927_181618.mp4 20240928_192844.mp4
    • It's in the bloody domain name twice! Yes...the GTR boxen have, for some reason, been cheaper than the RWD boxen for a long time. 10 years ago the GTST box was available here for <AU$3k. 5 years ago the GTT box was available for ~AU$3300. Both retail through 3rd party. Now the GTT box is >4k locally and only available for less if you're willing to jump through some hoops. Apparently they can be ordered from Nissan dealers for $3-3.5k at trade pricing. A friend of mine has a new GTT box sitting on his showroom floor that I keep wanting to hit him up for but I'd somewhat rather he sold it to someone else at his asking price than to me for a mate's rates discount.
    • lol I didn’t even notice the bird
    • I like the 'Beatles album cover, but with bird' element of this photo as well, haha
    • Hi Gents, Someone I know (experienced engine builder) built an engine. It had some chinesium rods that came with ARP 2000 bolts. One failed on the dyno, destroyed the whole thing. The only possibilities are: Installation error. Possible, but we should discount it almost 100% because he knows what he's doing. He doesn't discount it that much, because he's being hard on himself. QC/QA problems with ARP products. I'd like to discount this, but I have heard a number of stories about similar failures, and stories of some builders buying 2 sets of everything, x-raying everything, and picking only those bolts that they are completely happy with. This behaviour coming from anecdotal stories of ~1% failure rates. 1% of all rod bolts failing would be about 1000x higher than I would expect to be anywhere near tolerable. If I were ARP I certainly wouldn't even be selling the product if they were dying at that rate (for non-installation error reasons). So, I would prefer to discount that possibility too. Fakes. Specifically, fakes being sold bundled with cheap rods sets from CCP factory B in Shenzen, or wherever the stuff is being made this week. So the question here is, does anyone else have some horror stories that would point to fakes being circulated in this manner?
