Get a hair cut and get a job Josh. :(
I have a hair cut; bollockser cost me $250 as well. It’s just a little longer in length, then most “normal” people haha.
As much as I should get a job, I really can’t. I’m involved in litigation (still) with my bank. If I work I have an income, thus known money assets in known bank accounts.
If I don’t work, what the situation is stays the same and would be ruled in my favor. Some people say it’s corrupt, personally I’m using legal loop holes to fix something that shouldn’t have happened
the mod plate covers the 2 seater mod, roll cage, turbo, induction, suspension and pretty much everything else. Its registered as a 2 seater as well. The only dramas with it atm are the screamer pipe, ride height, exhaust volume and BOV...
Thats good news, when you said it had a screamer i thought what else went past the eyes of the mechanic that did the roadworthy...
Just the fact that there is no longer an airbag and the headlights are series 1 units makes me wonder if it has had a front ender at some stage of its life...???
I did a quick count of Jaqules list and there are at least 18 people on there that don't even own Skylines let have one that runs!!!
I got enough parts to make a whole skyline again, but I didnt strip it out of the donor to put it back together in its original chassis... :D
loses a lot of power, but fine for putting around on the streets, and takes 20 seconds to install/remove.
Like your kind of thinking :thumbup:
he's provided me with the original steering wheel with airbag included. the series 3 front lights were swapped during compliancing. The silencer is harder to fit than i thought.. not because its complicated, but just cause the bastard of a thing is a really tight fit and requires a bit of elbow grease to get it in. so ill revise 20 seconds to '2 minutes' :D having an absolute blast.. car is really well put together.. engine loves revving, and sounds so angry. im not ready for the march 25th track day, but ill be at the next one :D
heres a pic from today:
I find it just doesn't respond enough.
You're just too used to it Geoff. I'll give you mine for a wk (pre-tune) & that should put it all back in perspective for ya :D
320Kw would do me for a 'lil while
It’s not that old.. It’s a 1990, although the technology in it is still 30 years old lol. Water-cooled one's are the devil… Can you tell what part of the Porsche car club band camp I come from :D
They are more of a driver’s car IMHO, takes a whole lot more to control one, I find GTR’s boring, predictable, unexciting and an easier car to drive, plus I hate 4wd/awd… But I am narrow minded and don’t like all this technology, atleast I can admit it haha. Admittedly I’ve never driven a GTR like old mates one he just bought, but driving a 600rwhp S13 for a few years makes me a bit rwd bias I guess
There is no doubting that the GTR is the better, more advanced car (compared to early Porsches) and will win every time against "most" of the earlier 911’s. Although, we had a genuine RUF a little while ago, that would, could and still would (if it were still around) dust most mild GTR’s.
But that’s kinda comparing different leagues and not really relevant.
Yall own Nissan Pulsars :D All this from me hating tire to wheel arch gap :D
no drives for you then joshy :D
Get a mate to flim you doing fly byes on boost. I wana hear it at WOT :D
+1
ur forgetting about the 500kg weight penalty everytime geoff drives it...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
