I did get my fingers bent backwards by a hot little 20 year old girl at a t-shirt shop... Long story...
But the short version is they try to get you into their shops as when you standing in front of the shop another shop keeper can come and get you and pull you into their shop. Once your in a shop the other shop keepers leave you alone. So here I was standing out the front of a T-Shirt shop and the shop keepers daughter was sent out to pull me in and cause I refused to come into the store she bend my fingers back while laughing and saying "come in". I snached my hand back and moved on quickly, but yeah she was hot she was the bait to get western men into he shop... :closedeyes:
Vietnam and Thailand
Yeah Vietnam for 2 weeks (The whole country top to bottom) and Bangkok in Thailand for a couple of days...
Oh and I took my camera everywhere, and never spotted one skyline at all...
Didnt even see a Nissan, 95% of cars are Toyotas in Vietnam...
any one done part of the silk road? central asia
taking younger bro for 2 weeks in the new year
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
