Anyone wanta buy my ZX6R???
Its going for trade in on Saturday unless someone takes it off my hands sooner...
Have signed paperwork at $7600 trade...
So if you want it, obviouslly it can be your for that money, as the dealership is only going to turn around and sell it for 10k+
Which is farkin cheap for an 04 with less than 17k on the clock... ;)
The cheapest on bikesales.com.au in similar condition is $10,990
Just thought id post a quick comment as its no skin off my nose if no one wants it...
Guys,
I went to buy a rear strut brace and was sold a front instead, so before I take it back is anyone interested in a polished JIC front strut brace to suit an R33. I will sell it for what i paid for it ($220) if not I will take it back and get them to provide the correct one.
Cheers
Mushroom
damo i thought i told ya not to strip man your scaring the kids for gods sake!!
P.S hows the batt?? and whens the sexy pic shoot tell aliesha no luck wit da modlez
i sowwi but i know the kids like it :P
battery seems fine still need to go to ECC to get all wiring checked and get my Power FC put in :blink:
and the sexy pic shoot with aliesha will have to wait as she is in syd and models you say :blink: and sif you cant get models
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
