my friend wont know for a little while, but dont give up hope yet. thats not a no, just needs a bit of time is all, sorry :P
Edited by lilmike86
thats cool....
i rang the cops yesterday, they said that we both have to go to court regardless... and as he has a witness (his wife g/f whatever) i reckon it could be difficult.
yeah.. it would be a different story if he had done any damage to the car, or me, but as it was he hit like a girl so i dont have medical evidence to backup the claim anyway.
Mind you, i reckon he would have previous charges like this, so i'm still thinking it over.
if nothing else, i'm sure karma will catch up with him... karma being the name i use for the machete i keep in the garage (now in the car :P )
hey just letting everyone know that i'll be donating blood again today at the springwood ARCBS.... anyone whos got some free time today should come down aswell its for a good cause :P
CLUTCH IS ALL FIXED!!!!!!!!!
w0000000hhh000000
u know ur main problems
a) its an NPC clutch
b) its a twin plate
hey just letting everyone know that i'll be donating blood again today at the springwood ARCBS.... anyone whos got some free time today should come down aswell its for a good cause :laugh:
awwee i thought i was going to slash ur wrist and take ur blood next time :rofl:
blood + donate = not a good combination.
agreed :P
b) its a twin plate
umm, its cause of the spiggot bush which has been changed over to a nismo needle thing instead now which helps with better gear changing and seems to be alot better for the gearbox.
Guest
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
