Woof, hey Stephanie, hows your night going so far?
ahhhm pretty slow, im having a quiet night in, its one of my most treasured day off's so far, just been chilling out around home
IS there any good events on this sat night? sat day?....sunday day?
The thing that raises intake temps and makes intercoolers less effective?
Ahhh, no, its the thing that means I dont have to wear my wetsuit down the beach in SUMMER!!! Which is just insane. I'll put up with a less effective intercooler for a nice warm day down the beach.
ahh it is fun trust me I am helping dan with a couple of engines whilst waiting for my parts to arrive (damm supplier is now out of the type of turbo i want grrrrrr). Only thing is remember oil goes everywhere and to have a steady supply of rags avalible :)
Predictable ending but funny nonetheless... :)
TRADITIONAL AUSTRALIAN FARMING:
* You have two sheep.
* You sell one and buy a ram.
* Your flock multiplies, and the economy grows. You buy out your neighbours.
* You sell the lot and retire on the income.
AN AUSTRALIAN CORPORATION: (Workchoices!)
* You sell one, and force the other to produce the wool of four sheep.
* You are surprised when the sheep drops dead.
FRENCH CORPORATION:
* You go on strike because you want three sheep.
JAPANESE CORPORATION:
* You redesign them so they are one-tenth the size of an ordinary sheep and produce 20 times the wool.
* You then create clever sheep cartoon images called Sheepkimon and market them worldwide.
GERMAN
CORPORATION:
* You reengineer them so they live for 100 years, eat once a month, and shear themselves.
A BRITISH CORPORATION:
* Both die from foot and mouth.
AN ITALIAN CORPORATION:
* You have two sheep, but you don't know where they are.
* You break for lunch.
A RUSSIAN CORPORATION:
* You count them and learn you have five sheep.
* You count them again and learn you have 42 sheep.
* You count them again and learn you have 12 sheep.
* You stop counting sheep and open another bottle of vodka.
A SWISS CORPORATION:
* You have 5,000 sheep, none of which belong to you.
* You charge others for storing them.
A CHINESE CORPORATION:
* You have 300 people shearing them.
* You claim full employment, high productivity, and arrest the newsman who reported the numbers.
A NEW ZEALAND CORPORATION:
* That one on the left is kinda cute...
Hmm.
Ive never seen the inside of a RB. Most intresting.
its a bitch to do, but at the same time i enjoy it
ahh it is fun trust me I am helping dan with a couple of engines whilst waiting for my parts to arrive (damm supplier is now out of the type of turbo i want grrrrrr). Only thing is remember oil goes everywhere and to have a steady supply of rags avalible :P
the only 'mess' i made was when i took the turbo coolant lines off & the coolant dripped a bit, other than that no leaks or mess anywhere (other than on my hands and clothes) :)
im still @ f**king work...
so over it... I have done... get this... since I got in here:
Closed off some jobs that had allready been completed.
Twideled thumbs.
Gone for drive to shops. Gotten frozen meals as steph wont let me eat fast food anymore. For the record, they are shit. I ate half of one. Thanks hun for looking out for my health.
Twideled thumbs.
Got excited when phone rang, only to find it was coworker checking the lines.
Twideled thumbs.
Gone to car, gotten PC. Played games for 2 hours.
Now Twideling thumbs again.
Guest
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
