yeah cos John passed out on the couch last night, Shane didn't get any!!!
hehehe :P
Maybe he got some BECAUSE John passed out on the couch... :P
I bet his butt looks like one of those Top Deck chocolates right now... a thin layer of milky white covering a slab of brown
no it'd be more like white malteser's. Milk chocolate outside crunchy white stuff inside :P
Edited by lilmike86
:D
SO WRONG!! YET SO SO FUNNY!!!!
:P:(
i'd like it if he would just follow through for once :P
only if you Swallow :(
or even Gargel like thoose chicks on the Bang Bros movies!!!
fark me some of the girls those guys get to do are so farken hot :P
only if you Swallow :P
lol. i've heard that as a joke before.
Q. Whats the difference between toothpaste and cum?
A. You cant gargle toothpaste,
and marc is right, they would be dirtier than a public toilet at the ekka
Mike now dont tell me you haven't slept with women that have fallen into this catogory :P
yeah, i know a few. i saw one gargle a whole mouthful once, that was pretty cool. then again it was toothpaste :P
i wouldnt touch them with my 10ft pole...... heh.
Depends how desperate i was, and how drunk i was, and how dark it was, and how much dettol they used.
Edited by Oblivion
Depends how desprite i was, and how drunk i was, and how dark it was, and how much dettol they used.
dettol on your pole :P would that burn?? :P
Lubes better trust me :(
he he he
:P
gheyest comment of 2007
Quick, come and stand over near that comment so it looks comparitively less ghey!!
But meh, sif not wanting to go near a skank is ghey. They're a disease lottery, and would be like banging a bowl of mince.
Guest
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
