I have a huge compressor, guns ect, you would be surprised what we fit here Darren
yeah i got all that shit at work i can use it any time and a booth for smaller stuff.
if im in the hood 2moro (since its ya day off) il do a drive by and see your progress.
"Go placidly amid the noise and haste, and remember what peace there may be in silence. As far as possible without surrender be on good terms with all persons." ~Max Ehrmann (Desiderata 1952)
Ooooooh, I know! I will post the story of my horrendous day in here! I already told all the NSW whores, but I know those of you that are in here at night would LOVE to know >_<
I woke up at 3.46am this morning to one hell of a crash! Then there was rustling, and talking... I naturally thought people were breaking into my house! So I sat on the bed for a bit, wondering what the hell I should do. Andy wasn't there, so I was thinking whether I should wake up my housemate... hrmmm... I tapped on his wall... no sound... so I knocked on his wall... no sound... eventually I get off the bed and wander over to my bedroom door!
I can see a light coming from under the door... f**k! Someone IS in my house. Noooooooo... I don't hear anything for a while, so I open the door and peek out... nothing seems to be out of order... so I take a wander out into the loungeroom... still nothing... I can hear voices... I look out the front door and see a ute with a great pile of stuff in the back! They are loading stuff into it from garage number 3. WTF? So I stay up for a bit, and eventually they close the garage door, and drive off. I go back to bed. Can't sleep. I lie awake until about 5.00am. That's when I hear my housemate get up to get ready for work *sigh*
I must have fallen back to sleep at some stage, because when I wake up, it is to my mobile ringing, not my alarm clock. I look over, and the time is 3.30am... wait a minute... that's not right! I look at who's calling, and it's work. I answer it. They want to know where I am! I say... I don't know. I will call you back. Then I check the time on my phone... 9.03am! ARGHHHH!!! The f**king power went off some time between 5.00am when I went back to bed, and 6.00am when the alarm was meant to go off!
So I jump out of bed, call a cab while i'm ripping my PJ's off, throw on a random outfit hoping that it matches, and run out the door.
so whats the deal with the people robbing the other garage? you just let em help themselves? why didn't you call the cops? or get the rego number of the ute?
well, number 3 has been vacant for MONTHS... but she keeps coming back to get random stuff that she's left behind. So when I saw it, I just thought it was her and her brother back again! It didn't really click in my mind that it was 4am >_<
Guest
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
