lol sux 2 be u i guess. but why would you wait? i'd just say no then walk out mid speach
well i was seriously looking and i was going to ask prices but this guy, he asked me what size i wanted, i said 18s, and he goes nah 18s would look bad, u need 19, or 20s
HMm so whose going on mountain run
18's would be fine, 19's or bigger would be overkill.
i'm going tonight
POWER FC, or if ur keen to cut up ur loom go for an Autronic
LOL haltech's suck major wang, just ask dave :)
as Dave from NSW would call them, autistic. It's f*kn great thought... except for that one time it just died for no reason and we had to drive over 80kms at 20kph because he couldn't accelerate anymore :S But apart from that one time, he seems to be a big fan!
reset your ecu. unplug the battery and leave it for a bit. should reset itself. try it then
edit: also check your wires on the ecu and AFM's could have come off or something
Edited by lilmike86
Off home see you guys tonight!!!
Good luck Ian hope you get it fixeed!!!
stop bloody posting and get stuck into it!!!
bye bye mr lee :) will see you tonight. you better be wearing that dress there!
:mad:
or drive past the beat, or wickham u know why :laugh:
wrong end of town buddy :mad: I didn't mind the wickham. Had never been there til the pub crawl, but I thought it was fine :)
oh poor anna......literally *points and laughs at the poor one*
mmmmmm........hot girl just came into my office :)
yeh :) *sigh* I'll be in the val in about 20 minutes time. Having dinner with a mate from gladstone. But no drinking or dancing for me :)
wrong end of town buddy :mad: I didn't mind the wickham. Had never been there til the pub crawl, but I thought it was fine ;)
you wouldnt have any problems coz they like boys. wait, you might have :laugh:
gladstone huh, i used to live there. hated the town personally. no dancing :) well have fun :)
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
