dude... go to MSY at Morningside :huh:
wholesale pricing on computer equipment.
UMart buy their gear from MSY :unsure:
John, I checked the stock list and MSY don't even have the speakers I want and Umart are $85 cheaper than anywhere else I could find!!
Hey :unsure:
I need a new radiator...suggestions? Anyone know where to get PWR cheap?
from what i've been told, the less cores the better, and the greater the width the better, oh and go alluminium over copper
why PWR? thought about ARC?
Yeah Dave reckons multi cores are bad too so it is good to have that opinion backed up
I was thinking PWR for simplicity sake in that I can go and pick it up, I have made an offer on a ARC second hand rad from a R33 GTR, I am hoping that it will fit, as the GTST ones are interchangeable
the only arc they show is a 'side flow' no idea what that means, and it includes a breather tank.
i've seen an arc one, and the fin design is really good, in that the end tanks are tapered, and the first set of fins beside the end tanks are also tapered (the same with their intercoolers)
I will find the link to the exact one
well my pwr rad only cost 800 and it fitted perfectly. I got it from preadator motorsport as they were about the only place that could get them quickly.
Cool horse power in a box has them for 808
OK here is a logic test
A R32 and R33 Gtst radiator are interchangeable right?
According to ARC their R33 GTR and GTST kits are the same
THEREFORE Does a R33 GTR ARC kit fit in a R32 GTST
hmm unsure what about r32 gtr rad sizing?? I think it would andy but I would pm dan and ask him .
R32 GTR radiators are exactly the same as a GTST according t Dan in a convo I had some time ago
I hope this works out as this will end up being a really cheap solution for me!
http://www.greenline.jp/catalogue/bccatpar...ategory=cooling
It is the 55mm one part the way down the page
ahh i c, farken expensive :glare:
i was under the impression that the 32 & 33 ones arent interchangable. and i think if u run a thick core (say 50mm or so) u cant run the std fan & shroud
All the piping locations and stuff look the same, Yeah the losing the shroud thing isnt ideal but I think the improved efficiency of the core should more than make up for it
Guest
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
