I still don't get the NSW attraction..... everything costs more, the people all have large chips on their shoulders and the police are worse than ours. Plus it is not close enough for frequent visits so it makes me sad
have you thought of becoming a professional bum anna? they can make...........some money, and they thrive off being homeless :)
my brother found a pic of a bum holding a sign saying "will eat for food" i couldnt stop laughing when i saw it.
*sigh* here
I have no support to go to NSW so I don't really have a choice. Unless I want to be alone and homeless or whatever, I have to stay here.
i'll go with you Anna!!!
me ans my friend were really wanting to go and set up shop in sydney...
SO FARKING SLEEPY!!
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
coudlnt convince andy hey, ohwell looks like ur stuck with us for awhile longer :(
I don't want to convince him. I want him to go because he wants to. And he doesn't want to, so i'm staying here.
I don't get it either. But it's all I think about ALL DAY LONG!
lol i'm quite good at busking, bum stylez... I purchased the whistle/hammer I am using from the bum I am singing with. I paid him $10 for it :) Dave now keeps said whistle/hammer at his house :(
SO FARKING SLEEPY!!
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
BOOBS! ( O ) ( O )
thanks lee, i needed that :)
no i'm talking professional bum, like a beggar. there are people who make money doing this, and have made quite a lot. one man reported to have made 3k in a week. thats tax free too :)
also marc, were you the one that edited my sig?
No mike, not me
Lee, some of us are still at work... full screen pics of scantily clad women are nice (very nice actually :wub: ) but may cause problems for those of us who aren't already in the crap for reading whoretown at work lol
lee....
caught the train into work from southbrisbane to central today.
as i go through roma street
GUESS WHO I SAW SITTIN THERE ON THE SEAT?
2 hot asian chicks dressed in school uniform.
:wub::wub::wub::O
Have you been to the little japanese takeaway shop in sunnybank plaza yet? The one next to easy way tea? OMG the girl that works there is SO cute! And last time we saw her, she had these little ponytails with pink ribbons. Andrew nearly fainted :wub:
ok! group buy for this shop
and then she'll be all ours :wub:
hrmmm
gettin close to falling your lead anna.
i wanna quit now!
guys here just want, want, want.
they dont get the message when i say 'no, this cant be done, needs to be asked of from someone else' and then they turn around 'well, we need to go and get it from them'.
the other ppl have FAR better things to be doin then the crap these ppl are askin for.
Guest
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
