hey mike well i live near mansfield state high school so is that close by??
hmm i didn't know what I wanted to do at school and my guidance officer was a complete waste of space I agree let the kids decide they put too much pressure on kids too early as to what they want to do let them decide on their own.
Sweet as... cheers :wub:
no problem. tell her to call me if she has any questions and i'll help her out (just coz i'm the nicest manager at the company :wub: ) also, is she hot?
ahh take the diet of a fat man we can show you how to pack weight on :wub:
i have tried that! i dont gain any weight! i actually lose weight when i do that! my metabolism picks up the more i eat! if i eat less, it slows down! i cant win with it! am i doomed to have this perfect metabolism forever!
your probably all thinking i'm an ungrateful sh*t right now actually, most of you would kill to be able eat like me :wub: especially the girls
not sure about the girls but yes I would, i need to lose about 10kgs but well you get that thats why i took up scuba all that extra exercise has got to be good for me
hey dave :wub: how you feeling today?
Not too shabby, but taken lol
Same number and ask for you?
You so suck.
yeah well you are really close by Spilmer lives close as well as Sexyn
cool, i'll have to come leave flaming bags on all your door steps :wub:
nah marc, if she wants to call me, just pm me and i'll give you my office no.
bahaha i was waiting for that bit :wub:
do you blame me? cant say you wouldnt do the same
also, any posting of my numbers besides me will result in shane being castrated with a spoon
thanks mike but i think my two dogs may have a difference in opinion to that :wub:
you should come round one day and see my unicorn of a skyline.
hehehe thats what you think. chloroform filled cheerios :wub: sleepy time for the dogs :wub:
i was actually bout to say that! i have been hearing all about it and never seen it. would be good.
we'll i'll be at the dinner tonight so i'll just get it off you then. that way i can put a face to the number (unlike shane, coz they dont give children mobiles :wub: )
Guest
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
