awesome col!!!!!!!!!!!!!!!!! sound any different?
Oh yeah, Its heaps louder especially at idle...
Much deeper throaty noise...
Sounds awsome, ill film it tomorrow and ill finish off the oil catch can and ill try and drive it down the street, see if it makes some boost and hope nothing pops off... :/
Ive been told to replace my oil feed line, from the $150 braided and speedflow fitted unit to a PIRTEK crimped and tig'ed joint worth $220... But im a little peeved about spending the money already on the braided one...
But if its going to cause a fire i guess i better...
Oh and the wastegate sounds awsome even though its plumbed back its still loud... You can hear it shut closed when you lift off, and the turbo rolls down for a minute after you shut it down and thats just at idle... Talk about an awsome engineered turbine, im gonna time how long it takes to run down about a 5000rpm shut off...
I have a smile from ear to ear, ill post some pics and video tomorrow when i get a chance...
We came off the cliff near flaxton/Montville doing a mountian run last night... Scary/odd/fun. Movie to follow, how we:
<<<<<<<<<WHAT>>>>>>>>>>>>
85URK's car???
Oh...
I need pictures and a full explination... Col runs to call Josh...
yeah i dont know yet, im guessing they just lost it and went over edge of mountian, some of the roads up there are no mistake zones, u will fall off edge if not careful.
and good to hear your car's running col, post up you tube vids of it later on :/
That matt black RX7 looks like a chalk board... silly imo.
The blue is nice, but doesn't really suit a R32 GTR :/
lol Charade crashing... as if go on a mountain run in a charade... or anything FWD for that matter... understeer = death on the mountain!
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
