Me is good, How are you? still being a whore i see
she'll always be a whore
BBQ and Pool party at Anna's...
make it friday so she can supply the grog :ninja:
what on friday?
teh cruise u doosche :D
We all love Anna, and you look very similar in photos so im sure you could pass off as Anna if you both dress up the same...
Maby at the next SAU pub crawl you two can wear the same thing for shits and giggles...
i wonder which one andy will take home :)
Gotta jet lil ones!
Have a great night and i'll talk to ya's tomorrow :ninja:
"you'll work off that cake in the ACID MINES!!!"
bahahaha
laterz bish
"checking out the plumbing"
"testing out the pipework"
can someone tell me how to install my sounds card drivers so i can listen to music (im running linux, ubuntu, and sound card is soundblaster audigy 2)
havent installed drivers for sound cards
but if the rpm is on the cd which contains the drivers in a linux directory, go into the console and type -
rpm --i <driver-name>.rpm
that will automatically install it
LINUX IS FOR SERVER USE ONLY
DO NOT USE THIS AS A PERSONAL OPERATING SYSTEM!
last thing we need is n00bs whingin somethin about there computer isnt workin anymore and we find out they r runnin linux and not windows.
I run Suse 10 :thumbsup:
Are they mp3's? I know a lot of distro's leave out the mp3 playback side of things because of licensing issues.
Ubuntu should have had no problems detecting and installing the audigy.
More important though, I am now a SAU QLD member! woot!
quick a noob! flame him!! :thumbsup:
and i found even more toll reciepts, total now is around the $81 mark :woot:
PS: hackerX welcome to the club :P
I have all the dvds, so ive seen them, all :thumbsup:
You know u wanna come over daz and watch all seasons in a non stop marthon :woot:
Hmm sounds tempting, but i got season 1-6 of the simpsoin here i can watch., after i seen all them im gonna buy futurama and family guy, and american dad. but all in good time.
daz :thumbsup: do you know anything about caboolture? is it any good? i've never been there
its a ghetto.lol
nah seriously i know its got a train station, isnt the richest area around, yeah but other then that havent been there in a few years really, i drive past it on the highway and keep going to bris or goldy lol
its a ghetto.lol
yeah ive always done the same lol.. maybe its a really cool place but noone knows about cos they keep driving past it :woot: hmmm i doubt it :thumbsup:
Guest
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
