odometer only shows its done 2080km or something lol crazy.
why would you pay to put the ad up though, u know if it was a scam, some 1ring the number he has....
it says to contact the guy at his yahoo address, lol some1 is playing a prank on some 1 ha ha ha!
Could be one of the 12 skylines that where stolen from sydney about 3 weeks ago....
but i have emailed him....
put me down for 6 pls :thumbsup:
lol
trains have always been an interest
i've just started buildin my own track recently
but just put it away till i got a bigger place to set it up
so, just purchasin a few small trains to add to the collection till i can rebuild it again.
its that, or his missus aint puttin out for him and he's seriously bored :woot:
hmm probably why old guys get interested in it - watching those minature tube like devices going in and out of tunnels, through bushes, stopping at the station to unload, and being given the what for by the 'fat controller' for not obeying speed limits and arriving too early :thumbsup:
dude
u seriously got to build yourself one of these just to understand what its all about.
they're alot more fun then gettin ass raped by f**kwit cops all the time.
lol
atleast mines not 14yrs old and bein pimped out by goldcoast bikies :woot:
so who's would that be then? shanes? maybe he should become a bikie- look on the bright side, its ALWAYS moevember in a bikie gang :thumbsup:
dude
hmm that means they're not that much fun (as i wouldn't compare ass raping by cops to anything remotely fun) or you and i have very different opinions
meanin... with the trains, u can go as fast as u want, crash them till ur hearts comtempt, etc and not have the worry of a cop doin u for speed or crashin into others.
seriously, building your own land purely based on the structure of a railway system is a lot of fun. just like playin simcity :thumbsup:
Guest
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
