as far as gettin u from home to the movies last night?
dude, that movie was absolutely lame and for of shit.
somethings were funny but i dont even know how the hell it made it to the big screen.
nah, not even that far. straight to my local counsil park for some good ol' fashion bush bashing :miner:
the movie wasnt tooo bad, but there were better out there. still i had fun, good to see everyone again
when it starts up and begins loading windows. it locks up just after the windows loading screen.
i have checked the video card, tried re-installing windows and even put a different hard drive in.
still nothing, any ideas?
probably loading something in the background of windows like either a trogan or some software and its taking its time.
does windows fully load up?
no, it resets after about 30 seconds
edit: it just freezes on black screen
Edited by lilmike86
could me a issue with ram/memory.
or cpu is overheating
i can go through the entire windows setup booting off the cd fine, until it gets to the GUI setup screen
im thinkin more then likely either 1 of those 2 dude.
try swapin them and see how u go with that.
will do, i'll check it when i get home.
would a layer of dust affect the cooling of the cpu?
Guest
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
