:P
Hey Anna, I see your still enjoying yourself in whoretown...
How ya goin Col?
Hey Terry good mate....
I drove the skyline today for the first time in months...
She went supersonic on bridgeman rd out the back from my house...
28psi produced somwhere round the 350rwkw and she steped all over the road in 4th gear as she came onto boost... So im very happy, I have ripped down the back end of the turbo and am heat wrapping it all and just finishing off all the little bits before the dyno next Saturday for tuning...
The reason i hit 28psi was I didnt plumb the ext wastegate correctlly so ill fix that tomorrow and ill test it out...
Let me tell you its about twice as loud now when she comes onto boost...
Ill have to show you, you will be blown away as to how loud it is now...
The BOV is now mounted in the front right hand guard and the air filter is now in the front left guard so I have 2 separate air in and air out areas, complying with the ARD's rules and completlly legal... :)
well i'm gonna head off kiddo's!!
have a great night spammin ;)
Night Anna
kiss kiss
When I put my new turbo and front pipe on it was farkin loud too, I got a resonator installed in the straight bit after the cat, took alot of the growl out of it, its still loud but you have heard it and I wouldnt say its too loud, just right for me
Angry parents complained about a ninth-grade teacher who handed out a "joke" math test to his students that was offensive to Latinos. The mock test passed out by Charles Sanders included math problems such as: "(A person) is in prison sentenced to six years for murder. He got $10,000 for the hit. If his common-law wife is spending $100 per month, how much money will be left when he gets out of prison and how many years would he get after he kills her for spending the money?" Sanders was placed on paid administrative leave while the school district concludes the investigation. "We want him fired!" said Louise Palomarez of the Mexican Political Association. "We don't want no damn apology."
Can someone explain to me, why the holden hsv gts tv ad, has a thing that says australia 1, germany 0????/
i cant figure it out
dare say its to do with the soccer. Sad that obviously holden think they've made a better car than germany...hmm yea...ok. Even if they have (which i doubt) germany have like 1000 over us. so its more like 1 to 10,000
so they are comparing their shit car, to a soccer team???
honestly, i think i would take a german made car over an over priced VE GTS, they look to cheap.
hahaha soccer what fools
They are comparing that australia has better engineered vehicle & handling then germany does. ha ha i doubt it.
When the HSV GTS first came out (2000 or so?) they took it to the Nurburg ring against the (at the time) current M5 and the AMG E55. Anders Olafsson said the GTS was by far the best drivers car there and it set the fastest lap, wasnt as pretty inside but.
Guest
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
