yeah but it is nice to explore the limits of that block, and that way you can show others that a rb30 bottom end isn't the only way to gain performance
yeah good point...must admit, i'm keeping my rb26 bottom end and eventually putting in titanium sleeves just for when the rb30 breaks (bores are already 50thou oversize and the scratches on there are atleast 40thou deep)
mine is black (three coats of paint 5 coats of clear) it is real shiney so I had to start adding polished metal. I don't have any pics of the bay, or my new additions today but soon I will :whistling:
with headwork are you doing larger valves and springs? or just a port and polish? What sorta cams are you putting in? and what sorta power output you looking at producing?
Ah, secrets :D
Power will be around 400kw atw
thanks for the heads up mud, will make sure we dont damage that in ny way
all i can say is...HAVE FUN!!!
oh btw, be prepared for one of the engine mounts to get stuck, and if it does, dont just jack it up higher, caus they split in half :whistling:
Yeah, ive got new mounts waiting for when i break one/both >_<
well ill tel ya what happened
i had a 33, managed to get water into engine via cooler pipes (didnt realis til too late) thus causing hydraulic lock. so i went and swapped it for a stocko 32 gtr, i knew it had a stuffed clutch so i sent my 33 down on a truck to newcastle and i flew down and drove the gtr home. (driving all the way from newcastle to ipswich on a stuffed clutch that u cant bring onto the slightest boost, is very very difficult!!) so weekend after got the new clutch in, managed to put it side on into a gutter bending the left rear lower control arm. weekend after that i replaced the control arm on the saturday. sat nite headed into brissy for a cruise, got to toowong round about n started to hear a 'knock knock knock', got louder and louder, so headed home, made it and weekend after that pulled the engine out and stripped her down and found what i've described above.
so thats my story, and lets hope all goes well with the new engine :whistling:
thats cheating :whistling: ok single turbo or twins?
I am trying to decide solid lifters or hydralic anyones thoughts??
id say hydraulic would be easier to work with. being composed of buckets & shims its a piece of puss to 'adjust' them to give clearences required for different cams. dont know much more but thats just my opinion
Not sure what to say on lifters to be honest, and twins >_<
decided on what twins? i was going for twin gt3037's, but alas i wont be able afford the set-up at the moment, so its GT-RS's for me :D
so thats my story, and lets hope all goes well with the new engine :D
That sucks with the R33 >_<
And Thanks :)
decided on what twins? i was going for twin gt3037's, but alas i wont be able afford the set-up at the moment, so its GT-RS's for me :)
Secret twins :whistling:
Well, not really a secret like the head work, just custom 1 offs, so im either going to have a really good setup, or a sloth of an R32 - its a decent gamble, if the turbos dont suit me, they can be canged without much hassle, so thats good at least
ok cool as I have the following in th engine and want to make sure everything is looked after before it gets put back togehter:
Je Pistons (20 thou oversized)
Eagle H Beam rods
NCL bearings
Isk valve springs
Ferrier valves
Heavly ported head
Mark Ashford modded crank
ARP Studs
Inlarged oil pickup
A Turbonetics 60-1 turbo
Tial external gate
PWR rad and cooler
and lots of otehr shiney bits
I want to make sure I haven't left any waek links in the engine thats all
Eagle H Beam rods
NCL bearings
Isk valve springs
Ferrier valves
Heavly ported head
ARP Studs
Inlarged oil pickup
Tial external gate
PWR rad and cooler
Oil pump and Water pump N1 parts or standard?
what type of headwork you got done mud? i.e have the ports been re-profiled? and have the inlet and exhaust manifolds been match ported to the head?
camshafts? what are the duration & lift of them?
Guest
