Your house? I can think of a few people who might take offence to that bold and unfounded statement.
I can think of a shit load of people that would take offence to it, but I bet my sweet bitch tits they'd rather me call it my house than you!! ;)
Dude seriously, although I do get the feeling you're part female, you're clearly bored and looking for a fight... I'm going to clarify something for you... No one here cares enough about the internet to really fight, especially with a stooge...
So when u get sick of making a fool of yourself, feel free to push the lil X in the top right hand side of the screen....
*by the way, if you don't know your left from right, right's the hand you use to give reach arounds when your having anal sex with your bf*
Anna, this is the way most fully sick honda driving, tight tshirt wearing poof greeks act, they just need to be cut down to size.
thats not what you told me last night man you said that i was your world and you couldnt live without me. What happened??
HA HA HA
FULLY SICK ULEH!!!!!!!!!!!
roflcopter ;)
Better than Shane. Pick a boys name or a girls name, not both. WTF.
i think he means that there is no such thing as a greek warrior, they all just talk big then run away
hi anna :wub:
Morning! :)
herro anna dear :P
HI ;)
Anna Bear!!!
LMFAO
*wipes tears away from eyes*
what GIRLS do you know that are called Shane honey?!
BAHAHAHAHAHAHAHAHA!!!!!!!!
*whispers*
I think they were men!!!
I worked with a lady who's daughter was name cheyne. Pronounced shane. Weirdo.
LMFAO
*whispers*
lol i didnt even have to reply to that one. thanks anna ;)
cha ching!
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
