Thought all that gear was discontinued, with apexi going bankrupt and all...
sif bankrut the company making the chips for the power fc stopped making them thats all
Daz we have a spare had controller. if you are down our way drop in and iw can try both of ours in your car
yea, cool, but im not fitting the actual computer until i get all my mods. i just want to buy the right controller now. thats all, but was wondering how u tell what model my power fc will be (when i get it) and what hand controller suits it.
all i have to go off now is the model numer that is on the power fc, dunno if that is any help.
dude there are only 2 types of Controler.... the standard one and the AP enginering one....
if you have an rb25 it'll be the standard one if you have rb20 it'll be the AP engineering one...
you do mean Hand controller right?? :huh:
i CBF reading back and i only just jumped in to add my "expertiese" :laugh:
yes i mean hand controller , but have a look at this??
http://www.nengun.com/apexi/power-fc-hand-commander
well the info i have been given is, if your serial number starts with:
RB25 XXXXX then its older hand controller
and if it starts with ECR33 XXXXX then its the newer type one.
mine apparently starting with RB25 is the older type.
but i wont be ordering till i get my power fc in hand to check it. just to make sure.
when you get the computer drive down...we plug it in at my place, check the controlers by switching the key to on..thean wack your stocker back in once we know wich one works
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
