Age is old new. Pipe down, and listen to the future.
You know it's true. I don't hide it.
I smell pretty anna banana.
My tax is more then most people's income.
How sad for the common people.
Thats aboriginal for more bullshit
revert to my original post....go f**kyaself
Maybe your just so upset because your 52, you decided to have a midlife crisis, buy a skyline and become "cool" again to satisfy the need you never had in highschool.....but your realising that the young ppl don't like you now either...and you're realising how much you really do hate your life? It almost makes me feel sorry for you.
let me guess, this is aborigional for bullshit? Aborigionals really need to learn more words, although I almost admire their simplistic ways of making short conversations.
Obviously being a spoilt brat doesnt increase ones capacity to respond with a witty retort.
Why bother with wit?
My life is alreayd better then yours. Come say high to me at the dyno day, I have the Lexus in primer, i wont be mean to you honest.
Maybe your just so upset because your 52, you decided to have a midlife crisis, buy a skyline and become "cool" again to satisfy the need you never had in highschool.....but your realising that the young ppl don't like you now either...and now your realising how much you really do hate your life? It almost makes me feel sorry for you.
No, quite wrong in fact. For my midlife crisis I bought a used bart simpson figurine. cool again is also wrong. I have always been cool. Wether you like me or not is totally irelevant. I doubt that I will toss and turn worrying about it tonite. And, trust me puppy, I love my life. :(
p.s. wtf is high school?
you know the funny thing, matt and josh dont own skylines, they own TOYOTA's :(
P.S 6 bolt main, niggah please
I've owned more nissans than you i'd say, and all probably had more power than yours as well...so go back to your hole.
Why? cant afford to paint it? do you park it beside the caravan :(
Lets see now
180b
200b
swb patrol
swb patrol
long wheel base patrol
skyline
skyline
lwb patrol
lwb patrol
maxima
lwb patrol (current)
maxima (current)
skyline
and your list is?
Guest
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
