No worries... Happy too... :thumbsup:
As for the PWR we had her up just over 300rwkw then we turned her back down to 270rwkw to make it drivable...
what turbo are you running? What rpm does it come on? What boost? I had 320kw at 15psi but the fconv couldnt be tuned so i only ever really ran 12psi on the street which was enough, afr's were way to rich though and i continually fouled plugs....I miss driving/being in high hp cars :teehee:
Down the quarter mile yeah...
Ill take that bet... I get to run slicks on the rear and you get to run street tyres...
ur on :thumbsup:
oh and while we're at it, wanna put money on it too?
i'll be running street tyres, slicks are for girls :teehee:
Short story;
GT 30 0.82 rear
Ran 16psi to make 267rwkw @6200rpm
Ran 19psi to make 301rwkw @6200rpm
Boost came on hard at about 4300rpm...
Turbo is capable of 24psi so estimate about 400rwkw is its limit on a dyno dynamics dyno... But my motor is not going to handle anythign more that 16psi at a track day... So thats where it stays and then for dyno days we will run 19psi...
ur on :thumbsup:
Whats your estimate on my times down the quarter???
Considering I spent over 4 grand just on the rear rack, suspension and diff... So its setup for drag...???
Short story;
GT 30 0.82 rear
u do realise a forged motor will only set u back about 5k?
mid 11's
hey shane.. uh its little american but not strong..
im born in hawaii.. so im from all over the world.. ahaha
lol thats pretty funny
is this shane vs col??? Id put money on that..but i wanna see how both of you drive first, have either of you been to the strip before? What are your 60fts?
1.8 60' with 265x17x40 hankook k104 with a R33 gtst and 191rwkw :thumbsup:
full specs of both cars...is your car going to be set up for drag shane?
mine's too big to list, and i've listed it b4, however i'll go copy and paste it...and no, it's being set-up for circuit/hill climbs :teehee:
oh and i've done about 25 passes with my old car :thumbsup:
5k how did u spend 13.5 and not get it idling yet?
go all out lol
Guest
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
