We pwned dodgem cars
nice work on the spit, Matt. You took so long the clowns wanted to leave. I raced a hot house green hiace van thing with a manual 1jz. Do you know the car??
I beat it either way rofl
Edited by Nismo_Boy
yea I literally got stuck on a speed bump and everyone had to get out of the car so i could get off...and by the time I got back you were all gone....I dont know they van you speak of either.
:P WTF!! i just logged onto SAU and my anti virus is going nuts!!
adaware and a trojen while loading sau?? Who The f**k?? :D
you're fcked...start running the malware programs lol.
i turn up and he's no where to be seen :D
sleep?? sif sleep!! Sleep is for the Weak!! Mothers mixed with berrocca performance and coke zero FTW!! lol its a f**ked up taste but boy do you stay awake...
RON: *doing bicept curls* "Oh, Miss Corningstone, I wasn't expecting company. Just doing my workout. Tuesday's arms and back."
VERONICA: "Well you asked me to come by.
RON: "Oh, did I?"
VERONICA: "YES"
RON: *grasps arm* "Oh, it's the deep burn! Oh, it's so deep. I can barely lift my right arm 'cause I did so many. I don't know if you heard me counting. I did over 1000. You have your ubulus muscle that connects to the upper dorsinus. It's boring, but it's part of my life. I'm just gonna grab this shirt, if you don't mind. Just watch out for the guns. They'll get you."
Lol at Hot32 in the drag day thread..
Stock 34 with uped boots to 12, and runs 200kws.... hopes to make 14 sec
lol...
rofl indeed....if i didn't make 14sec's i think i'd cry..
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
