RUH ROH! What happenned sub?
It started idling rough as i was driving, i pulled over and turned it off. I started it again and the idle smoothed out so i drove it home.
Went to start it again and nothing.
Edited by subzeroR33
My car shit its self today.
I have this pain in my stomach.
Saw the thread in FI, its not something stupid like a bad batch of fuel, fouled plugs or blocked injectors? Maybe coils...
So it DOESN'T fire at ALL now? Doesn't even try to?
does the engine turn over on the key..Not siezed or anything major like that?
Yeah who knows mate it could be anyone of those.
Just the ignition, no motor.
thats cool man,
2 easy things to check are fuel and ignition, is it getting both??
Yes it is.
Changed fuel filter and its crankin over ok, Im hopin its coils or something electrical and not mechanical.
at least its cheap to replace those double post coils that you have if anything is wrong with them
Yes it is.
Sad to hear as your car is a beast. Let us know how it goes
cya all im off to work
AIR FLOW METER!!!!
Check it is plugged in properly, I had a similar problem and it was caused by my plug being broken..hence not getting a proper signal from the AFM
he runs a microtech, hence no AFM.
there is his problem right there!
His computers inbuilt aids finally reached maturity!
ha ha DOH sorry I could be of no assistance then
yeah he should have a haltech, then it could try to fill 2 cylinders with fuel and then compress it. would be heaps better
So tell me...
is it wrong that we just ordered 2 pizzas, a 1.25L coke, and a garlic bread, delivered, for $25.95....
and we have counted out and are going to pay the delivery driver that amount in 5 and 10c pieces?
ahaha gold.. let us knw how that goes... :(
Guest
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
